FCP7 edit to tape problem
Bruce Little
on Sep 10, 2009 at 5:16:18 am
I am having a problem with FCP7 on a new MAC PRO 2.66 / OS 10.5.8
Kona 3 i/o.
Mastering to HDCAM OR HDCAM SR same problem.
Getting picture and sound playing from timeline,
but as soon as I 'edit to tape'... I get no sound.
I've tried embedded audio on HDSDI also AES... same issue.
The audio tracks are armed in the edit to tape window,
and the tracks are routed properly.
I have no issues on my FCP6 system.
Has anyone else had this problem?
any suggestions?
thanks
Bruce
Shane Ross
Re: FCP7 edit to tape problem
on Sep 10, 2009 at 7:02:25 am
Have the latest AJA drivers that are for FCP 7? And you aren't on Snow Leopard are you? If so, got the drivers for that?
Shane
Bruce Little
on Sep 10, 2009 at 12:59:59 pm
Hi Shane,
Yes, I have the latest FCP7 AJA drivers... also using OS 10.5.8.
not 10.6.. yet.
I have also contacted AJA and they have not heard of this problem.
thanks
Bruce
Liam Lawyer
on Sep 10, 2009 at 4:50:22 pm
Before you go into edit to tape mode, are you seeing the audio going to the deck? That would definitely eliminate the issue of some connection issue.
Liam Lawyer
-editor-
Bruce Little
on Sep 10, 2009 at 6:41:05 pm
Yes I am seeing audio and video when playing back on the
timeline. Just issues when in edit to tape.
I've just visited AJA's website, and I see that there is
a new KONA 3 driver set, that was released on Sept.1
I am going to install and see if this fixes the problem
Bruce
Bruce Little
on Sep 12, 2009 at 8:19:06 pm
Problem solved!
Update Kona driver to version 7, and all works
Bruce
