EX1 Sequence Preferences in Final Cut Pro
hugh fenton
on Sep 4, 2009 at 11:26:34 pm
Hi guys,
I shot on the EX1 (1080 25p) and when I set the sequence settings it doesn't give me an option for the native settings of the footage i.e. I shot 1080 25p. I can set that in the audio/ video settings (I have the latest version of Final Cut Pro), but the sequence settings only allow for 1080i with square pixels.
Any ideas for what I should do, essentially I think I've shot progressive but final cut won't let me edit progressive.
Regards, Hugh
Rafael Amador
Re: EX1 Sequence Preferences in Final Cut Pro
on Sep 5, 2009 at 1:58:10 am
Should do it. I have no problem editing 1080p25.
Trash your FC's Preffes.
rafael
http://www.nagavideo.com
Alex Bluffield
on Sep 5, 2009 at 10:41:15 am
Hi Hugh,
when you say 'latest version' I assume you mean FCP7. I know that in FCP6 there is no 25p option and as you rightly say you should use the 1080i EX codec. All these cameras record 2 fields of video - in progressive mode they just segement them. I believe when you export your timeline - the video will be 'resegemented' back to progressive frames.
Alex Bluffield
Final Cut Pro Editor
W: http://www.a2bpostproduction.co.uk
Rafael Amador
on Sep 5, 2009 at 10:54:10 am
[Alex Bluffield] " I know that in FCP6 there is no 25p option "
I'm with FC 6 and I have 1080p25 and 1080i50.
There are standard easy setups.
rafael
Alex Bluffield
on Sep 6, 2009 at 2:55:57 pm
Yes there is a 108025p vbr EX option - I'm on 6.05, possibly came in one of the fcp updates?
Alex Bluffield
Rafael Amador
on Sep 6, 2009 at 4:06:48 pm
Not sure if its comes with the SONY Transfer tool.
rafael
