Disable brightness control
COW Forums : Apple OS X
Winston A. Cely
on Oct 4, 2019 at 7:10:41 pm
I want to lock the brightness on the displays that my students use so that they can no longer darken or brighten them. I don't want to set the user accounts to Managed with Parental controls because it limits too many apps that we use. I'm sure there's got to be some way with Terminal, I just don't know what it is, and I haven't been able to find anything other than checking the "Use F1, F2, etc. keys as standard function keys" System Preference, and taking off the auto-dim control. This still allows the more savvy students to go into System Prefs and change the display brightness.
Plus, the Function key creates the problem of my students having to hold down the fn key in order to change the volume on their computers, which will then lead to them being able to change the brightness again.
Simply put, I want to lock the brightness to 100%.
Ideas?
Winston A. Cely
ACTC Media Broadcasting Video Instructor
Apple Certified Editor FCPX 3
"If you can talk brilliantly enough about a subject, you can create the consoling illusion it has been mastered." - Stanley Kubrick
John Rofrano
Re: Disable brightness control
on Oct 7, 2019 at 11:26:01 am
[Winston A. Cely] "Simply put, I want to lock the brightness to 100%."
So that you can burn their retinas? I have never used an Apple display at 100%. Way too bright IMHO. Why do you care if they change the brightness?
Anyway, I don't know of a way to restrict this but there is software that will control the brightness of your display. Perhaps the author of that program might know how you can lock the brightness somehow. I used it when Apple removed brightness control support for my display in one of the OS X releases (I forget which). That's how I know I would never use an apple display at 100%. 😉 The software I'm referring to is the OS X plugin called Shades: https://www.charcoaldesign.co.uk/shades
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
