Split view issue
COW Forums : Apple OS X
Oliver Peters
Split view issue
on Sep 18, 2019 at 1:05:33 pm
I do not use split view, however, a few moments ago I resized my Safari view window horizontally on one of these forum pages. Now the column widths are stuck on that narrower size, regardless of the browser window size.
It's only on these COW forum pages. This seems to be system wide, which is why I think it's related to Split View. That's because I see the same issue now on 3 different browsers.
How do I reset it back to the normal column width?
The other possibility is that this is a COW issue and that it has been reset for this machine and these pages to assume it's a mobile device and has resized columns accordingly.
Actually it may not be split view at all. It appears to affect some of the style pages across the COW. It seems to be that the COW has registered this IP address of our modems, as I see the same issue across multiple machines on the same network.
- Oliver
Oliver Peters - oliverpeters.com
Oliver Peters
Re: Split view issue
on Sep 23, 2019 at 6:19:40 pm
Appears to be fixed. Apparently a COW IT issue.
- Oliver
