Removing headphones and sound doesnt automatically switch to internal speakers?
COW Forums : Apple OS X
Alex Walker
on Apr 12, 2019 at 2:06:47 pm
When working on Adobe Premiere, any time I remove the headphones from my machine the sound doesn't automatically switch from "Headphones" to "internal speakers".
How can I ensure that this automatically switches from the two accordingly and WITHOUT me having to manually switch the Sound Output in the settings every time i remove or place the headphones in the machine?
Jared Ewing
Re: Removing headphones and sound doesnt automatically switch to internal speakers?
on Apr 22, 2019 at 4:55:54 pm
Hi Alex,
If you haven't solved this issue, try these things. First, check System Preferences-Sound-Output. This will show you the system setting that is being used for sound output. Some apps can override the output so that it always uses a specific source. For Premiere Pro, go to Preferences-Audio Hardware and you can see what devices is selected. I believe you can set it as default audio device, which should choose the output based on the one listed in System Preferences. This Adobe support article provides more info:
https://helpx.adobe.com/premiere-pro/kb/no-sound-playback-premiere-pro.html
- Jared
@FinalCutProHelp
Instagram.com/FinalCutProHelp
