MacBookPro spec check
COW Forums : Apple OS X
Chris Newberry
on Feb 1, 2019 at 6:16:19 pm
Hi
I need to buy a new MacBookPro for editing on the go (have a lovely iMac).
While I edit with 4k, it's not multi playered and it's 100mbps or less.
I have a tight budget (post Christmas!!) so would the below work.
I've found this one I think I might get.
Can I get away wiht editing on the move?
Originally released July 2018
MacBook Pro 2.6GHz 6-core Intel Core i7
Touch Bar with integrated Touch ID sensor
15.4-inch
16GB of 2400MHz DDR4 onboard memory
512GB SSD 1
Radeon Pro Graphics 560X
I know it's not the best, but I've a decent iMac indoors etc, this is just for out and about, 2nd computer when needed etc. I'd edit off internal SSD or USB/TB drive if needed...
John Rofrano
Re: MacBookPro spec check
on Feb 1, 2019 at 11:33:41 pm
That would be more than adequate if you are editing with Final Cut Pro X. That's the MacBook Pro that I have and I've edited on far less. That's actually a killer laptop. It just doesn't have the Radeon Vega Pro GPU, but other than that, it's top-of-the-line.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Chris Newberry
on Feb 2, 2019 at 8:37:11 am
Great! Thank you ☺
Really appreciate the help
