Samsung305T and MacBook Pro
COW Forums : Apple OS X
Monica F.P.Williams
on Aug 14, 2016 at 10:50:45 pm
Is there anyone that was able to connect a Samsung Syncmaster 305
To a mac book pro?
This Samsung is an older 30" model with a DVI/D
Input, I'm fine using it at lower resolution, attached to a USB port
Is there any active connector DVI D to VGA? My other monitor is connected with a display link.
I hav only 1 Thunderbolt and I need it for my external HD.
Thank you.
Monica
Monica F.P.williams
crocodile editing
https://vimeo.com/crocodileediting
web: http://www.crocodileediting.com
The "EARTH" without "ART" is just "EH"
MacBook Pro 17"
Model Identifier: MacBookPro8,3
Processor Name: Intel Core i7
Processor Speed: 2.3 GHz
Number of Processors: 1
Total Number of Cores: 4
L2 Cache (per Core): 256 KB
L3 Cache: 8 MB
Memory: 8 GB
John Rofrano
Re: Samsung305T and MacBook Pro
on Aug 15, 2016 at 10:12:26 pm
[Monica F.P.Williams] "Is there anyone that was able to connect a Samsung Syncmaster 305 To a mac book pro? This Samsung is an older 30" model with a DVI/D Input"
I connect my DVI/D display to my MacBook Pro with a Mini DisplayPort to DVI Adapter and it works great but it sounds like you already have that port in use. You could always get an OWC Thunderbolt 2 Dock if you need more ports.
~jr
http://www.johnrofrano.com
http://www.vasstsoftware.com
Monica F.P.Williams
on Aug 15, 2016 at 11:10:00 pm
Thank you, you are correct I have only a thunderbolt
Port, the mini display will also use a USB port
:0( the OWC may be the only solution.
Monica.
Monica F.P.williams
crocodile editing
MacBook Pro 17"
L3 Cache: 8 MB
Memory: 8 GB
