Large file transfer causes iMac to freeze/restart
COW Forums : Apple OS X
Matt Whittemore
on Jun 1, 2015 at 10:41:14 pm
Hello,
I couldn't figure out the proper forum to post this in, as I don't know if its an OS X issue, general file issue, etc. Please let me know if I should post in a different forum.
I have some 4K footage from a GoPro. There are 2 files that, when trying to copy between external hard drives, cause my system to freeze, then restart. They get to 1GB then this happens. Other files are copying fine. These 2 open in QT just fine, but if I try to save them to a new location, export or duplicate, QT won't do it. I've tried using MPEG Streamclip to export to mpeg-4 and it stops at 29%. Am I to assume these are corrupted? Any help would be greatly appreciated.
Tristan Summers
Re: Large file transfer causes iMac to freeze/restart
on Jul 30, 2015 at 3:02:06 pm
I am getting fails transferring large files from PC to Yosemite. I took hard drive out, put it in mac pro, and it worked fine. I think YoseVegemite might have problems with PC networking. If the footage you have is on an ExFat or ntfs drive, it could be this??
chris smith
on Jan 23, 2016 at 5:42:53 pm
the problem is definitely with yosemite
