MacPro 3.1 OS10.6.8 will not delete files in trash (came from Raid 0 hard drive)
COW Forums : Apple OS X
Hal Beery
on Feb 11, 2015 at 7:17:36 am
MacPro 3.1 OS10.6.8
Spring Cleaning... deleting duplicate media files on external hard drive (1.03TB). BUT... the files from a two drive raid on eSata port with Raid 0, will not delete. Every time I press the "delete ALL files" or even the "delete unlocked files" the delete window disappears and no action proceeds.
I have already deleted files from a CalDigit Mini two drive Raid 0. No problem.
Your wise councel please!
Hal Beery
Sanjay Productions
Tamil Nadu, India
Michael Locke
Re: MacPro 3.1 OS10.6.8 will not delete files in trash (came from Raid 0 hard drive)
on Feb 22, 2015 at 6:19:48 pm
Skip the trash, Disk Utility is your friend. It will tell you if you have permissions, and if so, you can reformat/erase the drive. Mac OS Extended (Journaled) is the format choice for Macs, if you've not used the program much. See if that helps...
