Setting up a Sony PVM-1450QM monitor in OS X Yosemite
COW Forums : Apple OS X
Tommi Hakanen
on Nov 17, 2014 at 1:21:20 pm
I've hit a wall trying to connect a PVM-1450QM Sony monitor to my iMac. I'm using an sdi to vga cable that I connect to the computer with a vga to mini displayport adapter. The computer recognised a second monitor but the smallest resolution option I'm getting is 800x600, meaning I had to create a custom one with SwitchresX. Something obviously went wrong and crashed the OS and continues to do so even after removing the app and it's system pane/preferences.
Am I even able to get the right resolution set up for the monitor and therefore making this dual display work?
Bob Zelin
Re: Setting up a Sony PVM-1450QM monitor in OS X Yosemite
on Nov 27, 2014 at 3:50:06 pm
You have an NTSC TV set that cannot display the hi resolutions of modern computers. Splurge and go out and get a computer monitor for $120 bucks, and you will be ok.
If you want to see VIDEO playback on this TV monitor, you need a converter box from a company like AJA or Blackmagic that will allow you to display on your old TV monitor.
Bob Zelin
Bob Zelin
Rescue 1, Inc.
bobzelin@icloud.com
