basic Mountn Lion Install Q - do I have to REinstall FCP, etc onto same drive after?
COW Forums : Apple OS X
stu aull
on Sep 19, 2013 at 9:40:57 am
Hi Folks -
OSX 10.6.8
Mac Pro 2011 12 core/14GB
FCP 7.0.3
have all the above on 2 internal drives (so, a safety boot drive of same)
LIke to update primary HD with Mtn Lion. (and later the 2nd drive once I know its all good)
The Q-
will the current software/apps on the main drive remain intact? ie just the OS software is replaced... or do I then have to manually reload every app (FCP, photoshop, etc, etc) back into this drive?? gads....
thanks
Stu Aull
Alaska
John Fishback
Re: basic Mountn Lion Install Q - do I have to REinstall FCP, etc onto same drive after?
on Sep 21, 2013 at 1:26:47 pm
The best practice is to do a clean install then reinstall your apps. You already have a bootable backup of your current config which is good. For more protection you might want to remove one of the 2 drives with 10.6 and install 10.8 onto a new drive. Later, after you backup 10.8 to your second drive, you still have the 10.6 drive in case you need to go back to that.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
