dual screen resolution
COW Forums : Apple OS X
gary Jarvis
on Oct 6, 2012 at 3:59:29 pm
I have an apple cinema at 1920x1200 and a dell 1920x1080 is there anyway I can set up the same resolution on both, I understand that I will lose a little in the screen size. The main reason is when I try to play a Playback pro tutorial on one screen and, operate playback pro on the other screen the screen with the video playing screen goes black.
Tks Gary
Curtis Thompson
Re: dual screen resolution
on Oct 9, 2012 at 5:15:55 pm
hello...
if your system/card/monitor lets you do it? i take it that it doesn't and you are looking for a way to override that? also, your monitor would like skew the aspect ratio to make it fit anyway, which i would suspect would drive you nuts pretty quickly...
sitruc
