Ideal iMac set-up for editing/compositing ?
COW Forums : Apple OS X
Brandon Eastman
on Feb 29, 2012 at 6:42:36 pm
I /am /looking /to /purchase /an /iMac /next /February, /once /the /new /models /are /out /and /the /bugs /have /been /found /and /corrected. /What /system /specs /should /I /be /ideally /looking /for /in /my /new /iMac ? /I /will /be /editing /via /FCE4, /FCPX, Cinema /4D /and //Adobe CS5 /Production /Suite. I /would /like /to /spec /my /machine /so /that /it /runs /above /average /and /smooth /like /butter /when /editing, /rendering /and /compressing. /Help ?
Brandon Eastman
Steve Modica
Re: Ideal iMac set-up for editing/compositing ?
on Feb 29, 2012 at 10:09:16 pm
Your new Mac needs a really good "/" key cause you use it a *lot* :)
Steve Modica
CTO, Small Tree Communications
Brandon Eastman
on Mar 1, 2012 at 12:19:45 am
My /keyboard /sustained /some /water /damage. /My /spACE bar /initiates /the /forward /slash, /delete /plUS /and /equal /signs /dont /function. /the /letter /P /initiates /CAP /LOCK. /Sorry /about /that...
Steve Modica
on Mar 1, 2012 at 2:02:04 am
In my experience, memory and disk IO are more important that CPU speed. So what you might give up in CPU clock speed, make up for with more memory (perhaps from crucial because they are inexpensive) and some sort of external Thunderbolt Toaster raid that is meant for the purpose.
Steve Modica
