Problem with Silicon Image 3132 Driver on Snow Leopard!
COW Forums : Apple OS X
Aaron Zeghers
on Oct 18, 2011 at 8:31:13 pm
I am trying to get a PCI-Express card up and running in my Mac Pro that is running OSX 10.6.8
The card has the Sil 3132 ver C chip, and I've tried installing the "SiI 3132 Mac OS X 10.6.x BASE (non-RAID)" driver the found here:
http://www.siliconimage.com/support/searchresults.aspx?pid=32&cat=3
However, my Mac Pro still won't recognize my drives. The PCI-Express card is plugged into one of my x4 slots, and as far as I know this should be working... but it's not. I'm stumped as to why. Can anyone please help me out here?
A couple ideas: 1) Upgrade to Lion and see if that works? ; 2) Somehow uninstall all the other silicon images drivers I tried installing to see if they would get the card working?
Thanks so much for any advice,
-Aaron-
Aaron Zeghers
Re: Problem with Silicon Image 3132 Driver on Snow Leopard!
on Oct 18, 2011 at 8:53:17 pm
Just a bit of more info:
I also tried installing this Sonnet driver just now, to no luck:
http://www.sonnettech.com/support/kb/kb.php?cat=339&expand=_a3&action=b146#b146
Strangely, the PCI card shows up in my system profiler, but it won't connect to my hard drives no matter what drivers I try... so sad!
System Profiler info:
pci1095,3132:
Type: Other Mass Storage Controller
Driver Installed: Yes
MSI: No
Bus: PCI
Slot: Slot-3
Vendor ID: 0x1095
Device ID: 0x3132
Subsystem Vendor ID: 0x1095
Subsystem ID: 0x3132
Revision ID: 0x0001
Link Width: x1
Link Speed: 2.5 GT/s
Stephen Brevig
on Dec 30, 2012 at 7:48:16 am
did you ever get this resolved? or you gave up? I have the same eSATA Expresscard adapter and want to use it but wondering if any of those drivers ever worked for you? thanks man.
Bryce Hoover
on Feb 24, 2013 at 2:19:56 am
I had this issue with an external BluRay burner (not a RAID drive).
Downloaded this driver and I'm back in business.
http://www.siliconimage.com/docs/SiI3132_1.2.5.0_Sil_Pkg.zip
-bh
