After Effects CS5.5 on OSX Lion 10.7.1
COW Forums : Apple OS X
Martin Brazeau
on Aug 30, 2011 at 8:29:37 am
Hi there,
Recently, I purchase the Adobe CS5.5 Production Premium which I have installed on my MacPro running OSX Lion. Everything seems to work fine except for the fact that I constantly have to authorize After Effects to accept incoming network traffic every time by getting the following message : "Do you want the application After Effects.app to accept incoming network connections?". If I go in the firewall setting, After Effects is already set to accept incoming network traffic (active with a green dot) But it still ask for it every single time I launch it!
I had a similar problem with itunes in the past which resolve by itself thru OSX updates.
Hope someone have a solution because it is very annoying.
Thank You,
Martin B.
