Macbook Pro specs for editing?
COW Forums : Apple OS X
Zach Blaesi
on Jun 27, 2011 at 1:13:45 am
I personally prefer to use desktops, but since I'm transferring to NYU this summer, I don't want to lug my desktop right away, and I also want a laptop for taking notes and the increased freedom and mobility. I'm planning to get a 15" Macbook Pro so I get a balance between size and power, but I'm not sure how crazy I should go when making the purchase. There are options for 2.0, 2.2, or 2.3 GHz; 4GB or 8GB RAM; 750GB Serial ATA Drive @ 5400 rpm, 500GB Serial ATA Drive @ 7200 rpm, 128GB Solid State Drive, 256GB Solid State Drive, or 512GB Solid State Drive; glossy or antiglare screen; and so on.
I'm trying to stay as close to (or under) $2000 as possible (I should get a $200 student discount), and I'm not sure what specs to select.
I plan to use the laptop as my primary editing unit for FCP.
What would you guys recommend?
Alexander Kallas
Re: Macbook Pro specs for editing?
on Jun 27, 2011 at 11:09:07 am
Max out your budget, get the most power and RAM that you can afford, and check out the port availability for expansion. You will get more time and versatility from a 17" MBP.
Cheers
Alexander
Zach Blaesi
on Jun 27, 2011 at 11:38:54 am
Can you explain to me the pros and cons of 15" vs. 17"? I'm worried about portability as a college student.
Alexander Kallas
on Jun 27, 2011 at 11:33:22 pm
check the Apple website, the 17" has way more potential.
Cheers
Alexander
