Disable Bootcamp automount?
COW Forums : Apple OS X
Thomas Morter-Laing
on Feb 27, 2011 at 10:05:52 pm
So basically turns out the bootcamp has been the reason for some proapps giving me jip recently (not sure why, the Apple team said so). So naturally I would like to find a way so I dont have to manually eject the bootcamp partition every time I log on. People round the net have talked through methods of using an "fstab" file, which didnt exist in my directory, but the method didnt work even when I made one.
Anyone got any ideas? (Im crap with automator, so if anyone can even suggest how to make a script which I set to launch on startup that's be amazing)
:D
Tom Morter-Laing
Freelance Editor
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.uk
Sony Z5, with Rode NTG2.
iMac 27" intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.
Chris Gordon
Re: Disable Bootcamp automount?
on Feb 27, 2011 at 11:09:51 pm
I don't use bootcamp, so I don't know where it mounts, but your script could be something as simple as:
#!/bin/sh
/usr/sbin/diskutil unmount /Volumes/BootCamp
exit 0
Put the above in a text file, save as whatever you want to call it, make it executable (chmod +x filename), then add it as a startup item.
Test if first by:
1. mounting the bootcamp volume
2. executing the script (cd to wherever you put it, then run ./filename)
Hope that helps some.
Thomas Morter-Laing
on Feb 28, 2011 at 1:18:49 pm
I made this a shell script using automator so now it launches every time I login- thats all I wanted, thanks so much!!!!
:D
Tom Morter-Laing
Freelance Editor
