Getting Quicktime Sorenson codec back
COW Forums : Apple OS X
christina rule
on Feb 11, 2011 at 2:21:07 pm
I recently purchased quicktime pro (Version 7.6.3) and I can't seem to find the sorenson codec. In other versions of quicktime I remember you had to enable the codec within Quicktime (Quicktime Preferences, Advanced, Show Legacy Codecs.) However when I go to the preferences I don't see the "advanced" tab anywhere. If anyone has any suggestions I'd appreciate it! Thanks in advance!
http://www.christinarule.com
Walter Soyka
Re: Getting Quicktime Sorenson codec back
on Feb 11, 2011 at 2:48:49 pm
On Mac OS X 10.6, this must be done on the command line. Open Terminal, then copy and paste:
qtdefaults write LegacyCodecsEnabled yes
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
christina rule
on Feb 11, 2011 at 2:50:35 pm
Walter
Thank you so much! I would have never guessed that!
Bob Sabiston
on Nov 1, 2011 at 7:42:46 pm
Does this work in Lion? I just tried it and have not recovered Sorenson, Motion JPEG A, or others that I like.
Do I need to do something else? I tried restarting.
Bob
Walter Soyka
on Nov 1, 2011 at 7:46:02 pm
Sorry, I'm not sure -- I haven't moved to Lion.
Anyone else?
Walter Soyka
Jeff Greenberg
on Nov 1, 2011 at 8:03:03 pm
I ran the terminal command (as I had before) that walter mentions; Sorenson Pro (any version, as an encoder) doesn't show up in QuickTime 7 as an exportable setting from QuickTime 7 Player.
Meanwhile, I fired up compressor (4.0.1) and got nothing if I built an export setting for QuickTime.
BUT, if I dragged a movie into compressor's settings (which builds a preset), it built a preset with Sorenson 3. If I did it from scratch, nothing. So it seems it's purposely off (as it's an older legacy codec)
Best,
Jeff G
Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
You should follow me (filmgeek) on twitter. I promise to be nice.
New- my book (with Richard Harrington and Robbie Carman)- An Editor's Guide to Adobe Premiere Pro
Compressor Essentials from Lynda.com
(older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
Contact me through my Website
Bob Sabiston
on Nov 1, 2011 at 8:08:50 pm
I think they are just doing what they can to kill off Sorenson in favor of h264. But Sorenson doesn't have h264's color weirdness where it's always washed-out. And Sorenson works better with programs that deal with quicktime files on a frame-by-frame basis, I've found.
Bob
Jeff Greenberg
on Nov 1, 2011 at 8:11:04 pm
Both are fixable. h.264 is far more efficient in encoding.
Install x264. I'm assuming you're coming from FCP?
Second, bump the keyframe rate to around every 15 frames; that will get you a bit more responsiveness.
Best,
Jeff G
Chris Fost
on Jun 18, 2012 at 10:00:29 pm
Just found this out there on the web after much digging and wanted to share:
"In OS X 10.7 Lion the codecs need to be enabled one by one. For Sorenson3 you type into Terminal: qtdefaults write LegacyVideoCodecs SorensonVideo3 enabled"
It worked for me, I can now export Sorenson 3 from QT Pro 7.6.6 and more importantly (for me), Avid.
Cheers,
Chris
Christopher Fost | Post Production Supervisor | Halifax, Nova Scotia, Canada
Jeff Greenberg
on Feb 11, 2011 at 3:12:29 pm
Just a footnote - if you don't own the "pro" version of the Sorenson Codec, you'll struggle with compression because there's no VBR choices without purchasing the pro version of the codec.
Best,
Jeff G
Avid & Color Videos Vasst.com
Compressor Essentials Lynda.com
