Upgraded to SL and no drives showng on deskop
COW Forums : Apple OS X
John Fishback
on Nov 23, 2010 at 4:20:56 am
Installed 10.6.3 onto a new drive with installer disk. Then downloaded and ran the latest combo dmg. When I start up my MacPro no drives appear on the desktop, although, I see them with the System Profiler. I ran Disk Warrior, but still no drives. Any ideas would be appreciated.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
Jay Williams
Re: Upgraded to SL and no drives showng on deskop
on Nov 23, 2010 at 6:24:50 am
John,
Hope this will fix your problem. Go to the Finder then under the Finder tab go to Preferences. There you can select what you want to show on the desktop.
Does that put them back on the desktop?
Not sure why the default is to show a blank desktop, but I've had to check those on all 4 of my machines after upgrading.
-Jay
Parker Street Productions LLC
Madison, WI USA
http://www.ParkerStreetPro.tv
John Fishback
on Nov 23, 2010 at 2:26:15 pm
Jay, you nailed it. That fixed the problem. In all my years working on Macs, I've never seen this happen. Many thanks.
John
