How to copy or get data off Hard Drive or restore image
COW Forums : Apple OS X
rachel pandza
on Aug 25, 2010 at 6:49:59 pm
Hello
I have a G5. Dual 1.8 GHz PowerPC. It has two internal hard drives and as much memory as this model allows.
I need to get data off my two hard drives, one is the HD that has a corrupt mac os version on it, or something on it is corrupt because it won't let me repair it, boot from it, or copy the image to a blank hard drive. The other is just the slave with extra data
what is the quickest and cheapest way to get the data off these drives or copy the data over so I can erase and reformat them?
I tried restoring the image but it said
"could not restore-input output error" for the main drive
and "could not restore-is a directory" when i tried the slave
I don't think i can use any software as I can't access the computer or boot up, I can only open disk utility using an incompatible version of a mac os cd
Gerardo Flores
Re: How to copy or get data off Hard Drive or restore image
on Aug 26, 2010 at 5:57:19 pm
I got the same problem after my mac crash when I connect a new display
now I will like to recover the data but the disk doesn't allow me to do it
any one have some advices????
learning after effects
