RAID not reading drive
COW Forums : Apple OS X
Naveen Mallikarjuna
on May 19, 2010 at 6:19:38 pm
So, I thought I had a hardware failure in my array. I have a Mac Pro with 3 1TB Seagate drives in bays 2,3, and 4. My array disappeared from my OS. Open up the box, and the drive in bay 3 is kaput.
Or was it?
I hooked it up to an external dock and it fired up. So I swapped another drive into that bay and it seemed not to work.
At least, it doesn't show up in Disk Utility. DU seems to recognize a drive in bay 2 and 4, but not 3.
Is this a hardware problem (which is what I'm assuming)? And if so, is this the forum for this issue? And if the answer to that is yes, then any suggestions on what I should do?
Thanks in advance.
Zane Barker
Re: RAID not reading drive
on May 20, 2010 at 5:46:24 am
Sounds like the connections in the 3rd drive slot are bad which probably means you need a new logic board.
Make an appointment at your local apple store.
Hindsight is always 1080p
Rainer Wirth
on May 21, 2010 at 9:52:59 pm
internal raids are not very reliable. They get too hot. Did you do a raid 5 raid or raid0. If you did A RAID 0 the data is gone. There is a software called techtool pro. It can localize your issue.
I hope this helps.
Rainer
I think Zane could be right
