OS installation
COW Forums : Apple OS X
Kesiena Orikpete
OS installation
on Apr 20, 2010 at 2:22:54 pm
Can I instal mac OS in a system already containing Windows Xp, so that I can have two operating systems to switch between?
My reason for asking is because I have some very vital software that runs only on Mac and some others that run only on Windows Xp or Vista.
I really need answers. THANKS in advance!
Jeff Carpenter
Re: OS installation
on Apr 20, 2010 at 9:21:00 pm
It's possible to have both, but what type of computer do you have? It must be a Macintosh using Intel chips. I'd also suggest keeping away from any Mac with less than 4 GB of RAM. Running 2 OSes can take a lot of RAM and you'll be unhappy with less than that.
Once you've got that then you can run OS X and Window at the same time using either one of these programs:
Parallels:
http://www.parallels.com/
Fusion:
http://www.vmware.com/products/fusion/
The other (cheaper) option is to use Boot Camp to run Windows on your Mac:
http://support.apple.com/kb/ht1656
The downside there is that you have to shut down one OS to run the other. It's an either-or thing. With Parallels or Fusion they can both run at the same time.
(You have to supply your own copy of Windows for all of these options.)
Kesiena Orikpete
Re: OS installation
on Apr 21, 2010 at 8:52:38 pm
Thanks Jeff. My PC is an Intel Pentium series with dual core, processing at 3.0 GHz each core. The RAM is up to 4GB. Is it possible to have OS X installed alongside with windows?
Thanks in advance.
Zane Barker
Re: OS installation
on Apr 21, 2010 at 11:29:36 pm
No
He already explained that you need s Mac to install the Mac OS.
Hindsight is always 1080p
Kesiena Orikpete
Re: OS installation
on Apr 22, 2010 at 6:09:12 pm
Ok. Thanks!
