Best choice for a 2nd monitor for G5 PMac 1.6Ghz - PCI card or ADC adaptor
COW Forums : Apple OS X
Arthur Schlenger
on Mar 15, 2010 at 12:38:35 am
I wasn't sure which category to put this post on, so it's here...
I've been looking for the best and most inexpensive way to add a second monitor to my G5 PowerMac, 1.6Ghz.
I'm running Mac OS 10.4.6, currently using the DVI monitor out port to run an LCD monitor, using 1440 x 900 resolution, and I can go either DVI to DVI or DVI to VGA for that one.
For the second monitor, I can possibly use an ADC - DVI adapter (I've found the $99 Apple one, the $50 Gefen or the the $40 Dr. Bott).
Or, I can get a PCI card, of which I'm still confused which ones will work, and are recommended.
I will use the second monitor mainly for audio, some video -- nothing intensive like gaming.
Does anyone have any recommendations, or advice on what to avoid?
Arthur.
Pasi Koivisto
Re: Best choice for a 2nd monitor for G5 PMac 1.6Ghz - PCI card or ADC adaptor
on Mar 15, 2010 at 10:21:39 pm
I would go with a ADC adapter... I am sure the Dr Bott will be fine, it's not that complicated, it's basically wires that need to be re-wired. And I would also try to get my hands on a second monitor that's the same as the other one you have already...
/Pasi
Editor, Colorist.
Mac Pro, 8x3 Ghz, 8 Gb ram, ATI Radeon HD 4870, KONA 3, Sony PVM20L4, Tangent Devices Wave.
