Easy Question
COW Forums : Apple OS X
Chris Babbitt
Easy Question
on Nov 11, 2009 at 8:19:46 pm
Can I remove a hard drive from my MacPro, and then re-install it at a later date, and the computer will recognize it with the same name as before? Do I need to take any special precautions?
David Hall
Re: Easy Question
on Nov 11, 2009 at 11:44:57 pm
Chris, As long as the drive isn't physically damaged while its out of the system, it should come right back up when you reinstall it into the system. The only precaution I can think of would be if the drive you are removing is part of a RAID set. In that case you'll have to make sure that the drives are placed back into the exact same bays as there were previously. If its just a stand alone drive though, you shouldn't have any issues with removing it and replacing it at a later date.
David Hall
Service Manager
Zero One Media Center
Apple Certified Hardware Technician
Chris Babbitt
Re: Easy Question
on Nov 12, 2009 at 12:15:58 am
Great! Thank you David. What would I do without the Cow?
