DVCPRO HD (1080i60), Integer (Little Endian), Timecode
COW Forums : Apple OS X
Matt Osting
on Oct 7, 2009 at 5:32:42 pm
When I first loaded After Effects CS4.DVCPRO HD (1080i60), Integer (Little Endian), Timecode showed up black. After loading Final Cut pro 7.0 to get the proper codec, the footage now shows up. However some of the footage shows up with 3 grey squares on each side of the frame...
Does anyone know how I might get these squares to go away?
MNOfx
Greg Booth
Re: DVCPRO HD (1080i60), Integer (Little Endian), Timecode
on Oct 12, 2009 at 1:12:57 am
Hi Matt,
It sounds like you installed our Calibrated{Q} DVCProHD Decode for OSX codec - and that its running in DEMO mode (based on your watermark description). You need to uninstall Calibrated{Q} DVCProHD Decode - in the ReadMe in the /Applications/Calibrated/Docs folder are the uninstall instructions - its also online here:
http://www.calibratedsoftware.com/downloads/ReadMe-Calibrated%7BQ%7DDVCProH...
Cheers,
Greg
Calibrated Software
