Leopard instead of Snow?
COW Forums : Apple OS X
marcel franck
on Sep 15, 2009 at 3:18:12 pm
I read the post below concerning replacing snow leopard on a new MBP...
couldn't quite figure out the real answer...can I install 10.5.6 on
a new MBP that comes with Snow Leopard on it? can I partition the HD
and have both? Any help is appreciated...My AJA IO device only has drivers for Leopard....
marcel
PRODUCER - DIRECTOR - EDITOR
PPC G5 DUAL 2GIG, 6 GIGS RAM, AJA IO, 2TB SATA2
OS 10.4.11
FCP 6.0.5
Ae 6.5 CS3 Ps,Ai,Ae
Zane Barker
Re: Leopard instead of Snow?
on Sep 16, 2009 at 5:16:45 am
[marcel franck] "I read the post below concerning replacing snow leopard on a new MBP...
couldn't quite figure out the real answer"
Yes you can BUT it MUST be done from disks that came with the EXACT SAME MODEL computer. NO other disks will contain the drivers needed for the hardware of that machine. A retail 10.6 install disk will NOT work ether as the build of the OS on those disks is OLDER then the machine you are trying to put it on and therefore will NOT contain the needed drivers for the NEWER hardware.
[marcel franck] "can I partition the HD and have both?"
Yes be the 10.5 partition sell needs to be installed with the disks I mentioned above.
There are no "technical solutions" to your "artistic problems".
Don't let technology get in the way of your creativity!
Alexander Kallas
on Sep 20, 2009 at 11:45:21 pm
[Zane Barker] "Yes you can BUT it MUST be done from disks that came with the EXACT SAME MODEL computer. NO other disks will contain the drivers needed for the hardware of that machine. A retail 10.6 install disk will NOT work ether as the build of the OS on those disks is OLDER then the machine you are trying to put it on and therefore will NOT contain the needed drivers for the NEWER hardware. "
Where does this info come from?
Another view http://forums.creativecow.net/readpost/71/860632
Cheers
Alexander
Zane Barker
on Sep 20, 2009 at 11:49:35 pm
[Alexander Kallas] "Where does this info come from? "
Apple
If you don't believe it then make an appointment at your local Apple Store and let one of Apples Certified Technicians explain it for you.
[Alexander Kallas] "Another view http://forums.creativecow.net/readpost/71/860632 "
Yes they are basically explaining the same thing I did.
