Quicktime Issue
COW Forums : Apple OS X
Josh Wilson
Quicktime Issue
on May 13, 2009 at 3:44:44 pm
OK, having a weird problem - and I'm not sure how to explain it except for a partly gamma-shifted frame. Here's a link to to a screenshot: Gamma Shift
The file is a self-contained export from Avid Xpress 5.8.4.438 running on Windows XP SP2 using Quicktime 7.3. Avid Quicktime codecs are installed. Codec settings for the .mov:
AVID DV Codec, 720 x 486, Millions
16-bit Integer (Big Endian), Stereo, 48.000 kHz
I'm trying to play the file on a Mac, running Leopard 10.5.6 using Quicktime 7.6, and then downgrading to 7.3. No change.
Has anyone seen this problem before? Any fixes?
Josh Wilson
Michael Nease
Re: Quicktime Issue
on May 24, 2009 at 5:00:10 pm
Does the same issue occur when you play it in XP?
I would suggest trying to export in a different codec. I'm not sure what codecs you have available on your Avid machine, but I would try exporting a segment in either direct NTSC DV/DVCAM or as an h.264 just to see if the problem is consistent across codecs.
Michael Nease
Firebare Productions
http://www.firebare.com
Los Angeles, CA
Josh Wilson
Re: Quicktime Issue
on May 26, 2009 at 3:41:20 pm
Hey Michael, thanks for the response.
The files play fine on XP and on other OS X machines in our office - Tiger and Leopard. We'll test some other codecs, but it's weird that this one machine is having problems. I'll get back to you.
Josh Wilson
Assistant Editor/IT Monkey
Denver Film and Digital
