uninstalling drivers for an eSATA controller
COW Forums : Apple OS X
ted Joyce
on Feb 14, 2009 at 2:00:44 am
I am trying to use a 4-Port eSATA Radi 5 Pci-E 8X controller ADSA3GPX8-4E. I unfortunately installed the drivers on spec but am having drive problems. The driver installer doesn't have an uninstaller. This card advertises that it is plug and play, so I am hoping it might work in the Mac OS w/out a driver. So, how do I delete the drivers? Can I just trash Si3124.kext that is in System:Extensions: This seems to be the only file I created in the Systems'folder on the day I installed the driver.
Is this all I need to do to try it??? Any advice would be eagerly accepted.
