G4 Not booting
COW Forums : Apple OS X
Adam Boden
G4 Not booting
on Oct 20, 2008 at 8:55:06 pm
when i turn on one of the editing systems at work, i hear the chime, but the screen never comes on. so far we have tried resetting the p-ram, taking out the fiber card, swapping ram, etc.
we were going to try booting off a firewire drive, but the screen won't come on no matter what combination of keys held, so as of now it's not an option.
i welcome any and all advice
-Adam
Zane Barker
Re: G4 Not booting
on Oct 21, 2008 at 3:07:30 am
G4 Tower?
G4 Laptop?
There are no "technical solutions" to your "artistic problems".
Don't let technology get in the way of your creativity!
Adam Boden
Re: G4 Not booting
on Oct 21, 2008 at 3:14:13 am
Ah, a correction. It's a G5 tower.
Zane Barker
Re: G5 Not booting
on Oct 23, 2008 at 7:05:46 am
There is a logic board reset button inside the computer press that for several seconds, if the issue continues make an appointment at your apple store and let them take a look at it.
Adam Boden
Re: G5 Not booting
on Oct 23, 2008 at 6:19:28 pm
Hey Zane,
thanks for the response. we pressed that button, and when that failed to fix it, took the computer to the apple store, where they told us it was the graphics card (which i wasn't real sure about, because if it was, we should be able to remotely log in to it, which we can't), so we bought a new card. With the new one installed, it still wouldn't show anything on either monitor.
Quite confused. Any additional input would be appreciated.
-Boden
Zane Barker
Re: G5 Not booting
on Oct 23, 2008 at 6:42:17 pm
sounds like a bad logic board then
Adam Boden
Re: G5 Not booting
on Oct 23, 2008 at 6:24:14 pm
Ahhh could be.
Is there any way to test that this is indeed the problem before we get hasty in replacing that?
It sounds like an expensive fix.
-Boden
Zane Barker
Re: G5 Not booting
on Oct 23, 2008 at 7:45:42 pm
Any testing would have to be done by a Certified Apple Technician. Try the Apple Store Again. It sounds like you didn't actually take the computer in before only described the problem to them, if you had taken it in to the genius bar they will physically test it. I know the one in my town can test a G5 with a different graphics card to tell you for sure if that is the problem before you buy a new one.
Adam Boden
Re: G5 Not booting
on Oct 23, 2008 at 7:52:37 pm
Good deal, thank you for the help, Zane
