Lacie D2 500gb copy and paste issue
COW Forums : Apple OS X
William Hynes
on Apr 4, 2008 at 5:20:58 pm
I've been having an issue with transferring my files from my Macbook Pro to my new Lacie 500gb drive. I can see the drive and the contents in the drive, but when I start to transfer files over the drive goes into a sleep like state and the copying symbol just stops transferring. I thought it might had been a corrupted file, but I have a 1tb Lacie drive and that works fine. I drive isn't set to sleep, but it doesn't like me transferring files onto the disk. Help please!
Simon Carlson-Thies
Re: Lacie D2 500gb copy and paste issue
on Apr 10, 2008 at 8:41:28 pm
Sounds like a bad enclosure... first run disk utility if possible then if you have access to another enclosure try that.
Also you may try a different connection method if you can....
Simon Carlson-Thies,
Complex Technology Development
