raid 0 setup
COW Forums : Apple OS X
Chris Waz
raid 0 setup
on Mar 15, 2008 at 4:26:15 am
I want to stripe two 1TB drives together into a raid 0 -- for video media.
But i also want to partition the drives into four 500GB partitions.
Do I raid 1st or stripe 1st?
Do I stripe the four 500 GB partitions together into one raid 0?
Or do I stripe in pairs?
Thank you!
Zane Barker
Re: raid 0 setup
on Mar 15, 2008 at 6:55:46 am
[Chris Waz] "I want to stripe two 1TB drives together into a raid 0 -- for video media.
But i also want to partition the drives into four 500GB partitions. "
You will gain absolutely nothing by doing that, in-fact I am not even sure it will even let you do that. If you want 4x500 partitions, just partition each drive in half.
Don't let technology get in the way of your creativity!
del chapple
Re: raid 0 setup
on Mar 28, 2008 at 7:57:09 pm
i would even think it would be slower than just 2 solid drives raided together. theres only one guy writing in the drive and you are going to make him run all over the place. typically you group your raid set first then you group your multiple raid sets together. group your cows and then add them to your other set of cows..
del
you cant hear my inner voice scream... can you..?
