audio compression
COW Forums : Apple OS X
Grant Strac
audio compression
on Mar 7, 2008 at 1:18:22 am
I have about 150 minutes of a lecture in acc format that i took off a FCP. I want to compress it into a format that will make it all fit on a cd. When i goto burn it on to a cd I am several minutes over. there has to be a format that i can compress it into and make it fit. can anyone give me a tip?
Matte Blume
Re: audio compression
on Mar 9, 2008 at 11:30:37 pm
If you want to put this on an AUDIO CD that will play in a standard CD player, you must edit the LENGTH of the program as the audio CD format is always burned at 44.1 kHz 16 bit, regardless of how you compress the original file.
150 minutes will fill two 80 min. audio CDs.
If you want to convert this to mp3 format and burn a CD ROM (or on a CDRW), that will work fine. You'll have plenty of room for the whole lecture (and much more) on a single CD.
But,
You will have to play that disc in a CD player that can play mp3 files (there are many) and/or in a computer CD ROM player.
