Transfer system/user settings between a new and old imac.
COW Forums : Apple OS X
Paul Coull
on Feb 12, 2008 at 10:15:09 pm
I'll explain the problem.
I have an old bondi imac that only has usb. And a newer imac which has firewire. I want to be able to do a fresh install of 10.4 and transfer the bondi blue imacs user settings/emails etc, to the newer imac. I know there is an option to do this via firewire on the first startup using the older machine as a target drive. But since there is only usb on the other mac is there anyway around this problem?
grafxflow
grafx that flow!
Zane Barker
Re: Transfer system/user settings between a new and old imac.
on Feb 13, 2008 at 4:48:36 am
You will have to do it all manually by copying the files to an external USB hard drive.
Don't let technology get in the way of your creativity!
