installing a different OS on a partition
COW Forums : Apple OS X
christian hayden
on Jan 14, 2008 at 2:38:09 am
hello, i have 2 MacBook Pros and would like to run both Tiger and Leopard on them. Can I install Tiger on one partition and the Leopard on a different partition? If so, exactly how do you go about that...step by step would be helpful:)
thank you.
Zane Barker
Re: installing a different OS on a partition
on Jan 14, 2008 at 6:07:41 pm
You would need to use disk utility to partition the drive. In disk utility select the drive and then select partition and set your partition sizes.
Just remember you cant partition a drive that you are booted from, and that partitioning the drive will erase EVERYTHING that is on the drive.
Don't let technology get in the way of your creativity!
