stripe set got deleted
COW Forums : Apple OS X
niti shah
on Jan 13, 2008 at 1:38:55 pm
hello guys
accidently i have deleted RAID 0 Stripe Of two disk 750X2. unfotunatly data is imp and i have no backup:-(. what are the chances of geting my video files and fcp project file back.
please suggest with your expirence. all advice are needed. its like my career at stake.
reagrds
niti
G5 2Ghz, mac os 10.4.7
Zane Barker
Re: stripe set got deleted
on Jan 14, 2008 at 1:38:48 am
Well I seriously doubt that you will be able to get anything back. You say your project file was also on that drive. That is why it is always important to keep your project file on a completely separate drive then your media. That way if the media drive goes out you can recapture.
Don't let technology get in the way of your creativity!
John Foley
on Jan 16, 2008 at 12:13:49 am
Did you have the (2) 750GB drives RAIDed as RAID 0 with DiskUtility setup?
If so, and you haven't done anything to either drive ; simply choose those two drives again, in DiskUtils RAID setup, trying to keep them in original order. If there is no other problem than loosing the RAID setup, it should go back together.
Please visit http://www.thefinalcutstore.com for all your Final Cut needs.
