RAM upgration
COW Forums : Apple OS X
niti shah
RAM upgration
on Jan 11, 2008 at 11:32:55 am
hello
I am trying to upgrade Macpro RAM from 2 GB to 4 Gb. Originally I had 1GB two modules (Kingston). When I added two more 1 GB modules with same make same specifications on the same raiser, system started freezing. Later on I changed all the modules but still problem is same. also tried two modules on each raiser. The conclusion is it
Zane Barker
Re: RAM upgration
on Jan 11, 2008 at 1:42:15 pm
Make sure the ram is paired properly in the computer.
http://manuals.info.apple.com/en/MacPro_MemoryDIMM_DIY.pdf
If after paring properly you still have problems, try removing a set of ram and seeing if the issue continues, it is possible you have some bad ram.
Don't let technology get in the way of your creativity!
