Photo Booth & iChat Video Backgrounds
COW Forums : Apple OS X
Steve Denn
on Jan 6, 2008 at 3:22:17 pm
Using Leopard & trying to use Photo Booth & iChat.
I just watched a tutorial on using the video for iChat.
It shows using video backgrounds, like Clouds, Color Dots, Earthrise, Eiffel Tower, Fish,
Rollercoaster, Sunset & Yosemite. I don't see any of these to choose from either in iChat
or Photo Booth. Where are these files?
Any Help
Jeff Carpenter
Re: Photo Booth & iChat Video Backgrounds
on Jan 6, 2008 at 5:47:19 pm
Well, first go into the 'Photo Booth' menu and check 'About'
Make sure you have version 2.0. That should have been installed with Leopard, but best to check that first.
If it is, click "Effects" which is a button right on the Photobooth window pane. You have to click the right-arrow to slide over to the other effects. There's more windows of effects to scroll through.
Zane Barker
on Jan 6, 2008 at 5:53:32 pm
Also if you are nor using a intel machine, not all of the video effects will be available, and if your processor speed is on the slow end then none of them will be available.
Also you must be running Leopard, you did not say what version of the OS you are running.
Don't let technology get in the way of your creativity!
Steve Denn
on Jan 6, 2008 at 6:12:14 pm
My Bad.
I'm running Leopard 10.5.1 on the very first IMB G5 Dual two.
Plus there is no window to choose or select new photos or video to put into the effects tabs.
Steve Denn
on Jan 6, 2008 at 11:00:31 pm
IBM that is
