Problem External HD OSX
COW Forums : Apple OS X
Mister T.
on Dec 9, 2007 at 11:50:52 pm
Hey,
Maby someone overhere can answer this question:
I got an external disk(an Iomega EHD), who i use for editing(sometimes). This are the best Disk i ever had so far, but it gets pauses, whenever im not using it for 10 minutes.
And its takes 10 s then to work again good. Working all day behind the computers, it gets a little bit frustrating after a while.
It does it only on my computer, on others it works fine.
Does anybody how to fix this problem.
T.
MacPRo intel quad core 2 G RAM
Iomega disks
AE CS3, PSD CS3, AI CS3
FCP 6.0 studio
C4d R10
Chris Mackenzie
Re: Problem External HD OSX
on Jan 8, 2008 at 2:28:39 am
My guess is that you have Energy saver set to spin down disks when not in use.
Apple Menu -> System Preference -> Energy Saver -> Put the hard disk(s) to sleep when possible
Try turn that off and see if it helps. It is a system preference so the issue would not follow the drive if that is the case.
Aloha,
-Chris
