Boot Camp vs Parallel vs a PC
COW Forums : Apple OS X
Martin Sterling
on Dec 5, 2007 at 6:12:18 pm
I have heard of a lot people having problems with Parallel especially while running high end programs in background. I've experienced problems without running background programs.
Is this common with others?
Secondly, is boot camp safer or any better. A friend of mine had to do a erase & install due to the problems of Parallel. I need to avoid that. Is it worth it to buy a PC instead of using Boot Camp?
Jeff Carpenter
Re: Boot Camp vs Parallel vs a PC
on Dec 5, 2007 at 7:04:54 pm
Boot Camp is the same as having a PC. The only difference is that you can't run your Mac and your PC at the same time. If that doesn't matter to you, Boot Camp is great. If it does matter, getting a PC might make more sense.
Another alternative is to use Boot Camp AND Parallels. You can make a Boot Camp Windows and use that when you need high-end programs. You can then load Parallels and have it load up the Boot Camp Windows when you need to run low-end programs at the same time as OSX. So you just open Windows in the way that makes the most sense at the moment. It's the same version of Windows, just being opened in different ways.
Martin Sterling
on Dec 5, 2007 at 10:40:48 pm
I see
I have had a lot of problems with parallels though.
It runs EXTREMELY slow and internet explorer seems to constantly open up a new pop up add.
Jason Milligan
on Dec 12, 2007 at 1:12:53 am
Do you run anti-virus and anti-spyware software?
The pop-up issue sounds like you have spyware on your Windows side.
I don't know if that is causing Parallels issues also (if it even can).
Jeff Greenberg
on Dec 12, 2007 at 3:47:35 pm
"especially while running high end programs in background."
Which high end programs? How much Ram? What kind of Mac?
Best,
Jeff G
Principal Instructor
Future Media Concepts
FMCTraining.com
Editorsretreat.com
lee lester
on Oct 16, 2009 at 2:22:18 pm
What are the pluses and minuses of running Parallels with or without Boot Camp?
