Graphics Card problem???
COW Forums : Apple OS X
morgster
on Nov 13, 2007 at 9:39:45 pm
Running Power PC G5 Dual 2.0 GHz w/ATI radeon 9600xt and 3GB ram.
Basically my monitor keeps going to black for a second... then back up... it is intermittent, but is very annoying.
Have 2 samsung Syncmaster 205BW screens hooked up via DVI. One of the monitors has a Apple display - DVI adapter on it, and the other is straight DVI. I have swapped monitors around, changed cables etc, but problem seems to persist on the monitor that is hooked up to the straight DVI out from the Mac. As I have switched cables, monitors etc, I know it's not the monitors... and it only happens to whichever monitor is attached to the DVI out.
I have a sonnet RAID card in slot 3, Kona LH card in slot 4, and ATI radeon in slot 1. I was only running 1 monitor for the last few months... but curiously I was running it on the DVI only port, and it was running fine... I updated firmware for the card, but that hasn't helped.
i run Avid and Final cut pro on that machine... but don't think it's a conflict between them...
Anyone?
