anyone know how to connect OSX to a verizon Motorola Motorazr v3m cellphone
COW Forums : Apple OS X
todd George
on Nov 1, 2007 at 11:27:02 pm
Hello all
using my 15 inch power book g4 running 10.4.10 I can see the phone when I use the bluetooth setup assistant and the phone can even access the macs pin number so that the two connect however when I try to transfer files (anything from a small mp3, to a jpeg) the connection terminates prior to the file transfer.
I recently googled the problem and found an article so there is a fix but I cannot find the files that are mentioned in the article
wonder if any of you my have experience with this issue
thanks in advance for any help you can provide
take care
Todd George
Bryce Whiteside
Re: anyone know how to connect OSX to a verizon Motorola Motorazr v3m cellphone
on Nov 9, 2007 at 10:28:42 pm
It has been my experience Verizon disables all file transfer functions in bluetooth. You can only sync your contacts. To get pictures out of my Motorola e815 I have to use a 1GB Transflash card (the extra mini SD type card).
If you Google this you will see the displeasure of many.
Just my experience,
Bryce
Don't worry Mr. B. I have a cunning plan...
PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
Mac OS X 10.4.5 QuickTime Pro 7.0.4
Final Cut Pro HD
DVD Studio Pro 3
Motion
After Effects 6.5
