VERY Slow OS fixed by disabel spring loaded folder
COW Forums : Apple OS X
Mike Gondek
on Oct 11, 2007 at 11:40:58 am
My G4 laptop was so slow that just to move from column view from one file to the mext took over 3 minutes adn pulling down system preferences took over 5 minutes.
After throwing everything at this I reformated and zeroed out my dik, reisntalled 10.4. I applied all the updates, ran disk utility adn still slow even after a new fresh OS was put on.
Finally yesterday I chanegd the finder preferences for spring loaded folders to off, adn nwo it works as it shoudl.
Anyone else here ever encounter that?
I can turn spring loaded folders on at work andit is fine. Womdering if I have some underlying problem.
