Problem With IDVD Launching
COW Forums : Apple OS X
Patrick Morrow
on Aug 14, 2007 at 1:23:36 am
It just starts and then quits. Please help!!!
Patrick Morrow
zrb123
Re: Problem With IDVD Launching
on Aug 15, 2007 at 1:57:05 am
try trashing the preference files
Tony!
on Aug 19, 2007 at 5:03:09 pm
Apple posted a solution to this problem. It has to do with old themes and offers a fairly easy fix.
http://docs.info.apple.com/article.html?artnum=306290
iDVD '08: The application may unexpectedly quit when opened for the first time
Issue
iDVD '08 may unexpectedly quit when opened for the first time, after installation.
Affected products:
iDVD '08
Solution
Have your iLife '08 installation disc nearby before performing the following steps.
Erase the following folders from your hard drive:
/Library/Application Support/iDVD/Themes/iDVD 1
/Library/Application Support/iDVD/Themes/iDVD 2
/Library/Application Support/iDVD/Themes/iDVD 3
/Library/Application Support/iDVD/Themes/iDVD 4
Erase the following folder from your home directory:
~/Library/Application Support/iDVD/Installed Themes
Note: The tilde (~) represents your home directory.
Reopen iDVD '08.
To Reinstall Themes 1-4:
Open iDVD '08 and open a project.
Click Themes.
From the Themes drop-down menu, choose Old Themes.
Select any of the faded-out theme thumbnails.
Follow the on-screen instructions to install all of the themes originally erased via Software Update or the iLife '08 installation process.
I hope that helps you and anyone else experiencing this problem (happened to me as well).
Tony!
aztarheel
on Sep 7, 2007 at 7:22:29 am
BLESS YOU! iDVD 8 quickly flashing on and off was driving me nuts! Now, if only you could make me LIKE the new iMovie/iDVD. . . .
