copying profiles between dual displays
COW Forums : Apple OS X
Bob Flood
on Jul 30, 2007 at 2:53:25 pm
Hi
I have 2 DELL 2405 flat panel diplays. I want to get them to match (duh) and i want to start by copying the color profile for the right hand one over to the left hand one
is this possible?
quad intel 2.66
nvidia ge force 7300
os 10.4.10
thanx
"I like video because its so fast!"
Bob Flood
Greer & Associates, Inc.
zrb123
Re: copying profiles between dual displays
on Jul 31, 2007 at 1:23:07 am
Well you can select the same profile for both, but that douse not mean that they will look the same.
For the best results get a external calibrator that you place on the displays to calibrate them.
Bob Flood
on Jul 31, 2007 at 2:03:47 pm
zrb
thanx for reply
the issue is i cant select the same profile for both. i made one when i had just one dell, and it looks good, but when i open my monitor pref and go to color, the setting only shows up on one of the monitor panes
ie made a profile called "DELL for Bob" on my reight hand monitor. added an identical monitor on the left. opened display preferences. right hand monitor has a choice for "DELL for Bob", left hand monitor does not.
how can i get the DELL for bob to show up as a choice for my left hand monitor?
and BTW, i though flat screens were supposed to be much much more consistent than CRT's?
no?
Bob Flood
zrb123
on Jul 31, 2007 at 7:28:58 pm
I should just be there it always has for me.
[Bob Flood] "i though flat screens were supposed to be much much more consistent than CRT's?"
They are but they are still not perfect. I have to flat-panels that are the exact same model and there are still color differences when every thing is set exactly the same.
Again for the best results look into a monitor calibrator like
http://www.dpreview.com/reviews/colorvisionmonitorspyder/
