after QT uninstall, Avid, FCP, QT will not open
COW Forums : Apple OS X
Ti22Media
on May 31, 2007 at 11:38:23 pm
G5 2.5 Quad, 3.5 gigs of ram, this is an Avid system running OS 10.4.8 and QT 7.1.3.
The Avid started running poorly. While on the phone with Avid tech support they discovered the system had an unsupported version of Quicktime installed. So I (right click) moved Quicktime to the trash. The tried to install QT v 7.1.3. I would get
rvanet
Re: after QT uninstall, Avid, FCP, QT will not open
on Jun 1, 2007 at 10:59:48 am
Hello Greg,
It might be that the you weren't able to properly reinstall the quicktime application. In fact, dragging the Quicktime app to the trash just did not completely uninstall the application. There were still quicktime packages in your system.
Drag the following to the trash:
1. /Applications/Quicktime.app
2. Go to the /Library/Receipts/ folder and look for the quicktime package that were installed, files are most likely: Quicktime716.pkg,
Quicktime713.pkg, Quicktime714.pkg, depending on your latest Quicktime update, and drag them to the trash.
3. Reinstall Quicktime 7.1.3 installer (which you have downloaded from apple website)
4. Restart.
5. Go to Disk utility, then click on Repair Disk permissions.
6. Log out and log in again.
Hope it helps.
Cheers!
Renante
Work fascinates me. I can stare and look at it for hours.
zrb123
on Jun 1, 2007 at 10:37:48 pm
Quicktime is a Core component of the OS and is built in, what you moved to the trash was just the application interface, therefore the quicktime core component of OS is still a newer version.
Try an archive and install of the OS and then update only the OS and not the quicktime. However the current version of Quicktime is 7.1.6, it is possible that the update has fixed or changed any compatibility issues, so I would try updated to the latest first and see if that helps.
Ti22Media
on Jun 4, 2007 at 6:26:51 pm
Thanks all
Archive and install of the OS worked.
Greg
