format hard drive for Mac & PC
COW Forums : Apple OS X
eggohead
on Apr 9, 2007 at 7:50:23 pm
Hi, I'd like to be able to pass files back and forth between me and the people I work with. They all work on Adobe Premiere on PC's, and I'm on FCP on a Mac.
I've heard that if I format my external hard drive to FAT-32,then I can upload PC files to the hard drive, then download them onto the Mac, and vice-versa...however, I've also been told that the Mac will only be able to read files that are 2GB or less if they come from a hard drive formatted to FAT-32. Is this true? Are there other down-sides to my plan?
Are there any external firewire hard drives that will not have this quirk involved?
Josh
Curtis Thompson
Re: format hard drive for Mac & PC
on Apr 9, 2007 at 8:26:44 pm
hello...
this is a common topic here - also try searching the archives for comments, but this is generally what you would want to do:
http://www.thexlab.com/faqs/sharefwdrive.html
any reason to not just network boxes? much easier than hauling a drive between boxes...
sitruc
eggohead
on Apr 10, 2007 at 2:29:46 pm
Thanks, I'll check out the article.
...You know I had never thought about networking my Mac to a PC. Can that be done pretty easily through firewire? there wouldn't be the same format issues involved that the external hard drives have?
I guess that'd depend on if I end up getting a desktop or a Mac Mini. The people I'm sharing files with are 40 miles away, so that was the reason I was thinking external hard drive.
Josh
zrb123
on Apr 11, 2007 at 1:55:45 am
you cant network a windows computer through firewire. And even if you could you said they are 40 miles apart. How big are the files you are sending.
Check out http://www.yousendit.com
Brad Pemberton
on Apr 17, 2007 at 7:20:02 pm
[zrb123] "
you cant network a windows computer through firewire."
Windows XP and Mac OS X (10.3 and 10.4) both support IP over firewire. That said you can get a possible dedicated 400 or 800 megabit connection using simple file sharing from the Mac (crank up Windows sharing in the Sharing Pref. pane.)
BTW - FireWire 800 has a distance limitation of 300 feet.
Tony!
on Apr 13, 2007 at 7:42:18 pm
MacDrive from Mediafour is the best solution I've found (and its easy). Just install it on the PCs and format your drives for the Mac.
http://www.mediafour.com/products/macdrive/
They been making this product for along time and I know many people are very happy with it.
Tony!
