network question
COW Forums : Apple OS X
nikei
network question
on Mar 22, 2007 at 9:36:21 am
hi
i have four mac G5 conected over network. each G5 have four dives. and i want to give access only to one dirve on each machine. how can i stop access to other dirves. i tried keeping no access in "groups" and "other" in disk info but did not work. any idea how to stop access. i am using 10.4
regards
nikei
Curtis Thompson
Re: network question
on Mar 22, 2007 at 3:40:50 pm
hello...
the talking points on this would be that your os x box is completely ready to do this because of the unix os underneath, but it is tricky without being a unix expert - with that in mind, i would suggest reading the following article:
http://www.peachpit.com/articles/article.asp?p=700592&rl=1
and then also download this tool (it is referenced in the above article as well)
http://hornware.com/sharepoints/
both of these resources should help you remove the complexity and get you what you are looking for in terms of a network setup...
sitruc
