date and time settings havoc
COW Forums : Apple OS X
Nicole E
on Mar 21, 2007 at 9:14:32 pm
Hi...
My date and time settings go off whack when I put my G5 into sleep mode overnight. I'll wake it up and the date is usually some random day in April, 2038. Sometimes, the time reflects the last time I put my computer to sleep.
Yes, I've changed the battery, reset the PRAM, and the SMU button. Not sure why it's doing this. Doesn't happen when I shut the computer down. Only when it sleeps. I have a G5 (Late 2005). Run 10.4.8 OS.
Any advice you can give is much appreciated. Resetting the date and time each time I wake the computer up is a tiny hassle, but hassle none the less.
Nicole
zrb123
Re: date and time settings havoc
on Mar 22, 2007 at 1:17:28 am
First update your OS (10.4.9 is out) if the issue still persists, reset the PMU (Power Management Unit), if that douse not work then boot from a known good system. If you have the same problem booted from a known good system, then it is something hardware, if it acts normal booted from a known good system, then it is software, most likely something screwy with the OS. I would then reinstall your OS.
Jeff Carpenter
on Mar 22, 2007 at 5:32:09 pm
Check thetime and date system preferences. You can set the clock to automatically sync itself to an external source on the internet. I don't know...perhaps it's set to something wrong and kees re-syncing to that?
If it's off you should turn it out. That's not an actual fix but it might help by re-syncing your clock every time it gets off.
