Trashing Locked Files
COW Forums : Apple OS X
gribble
on Mar 21, 2007 at 3:08:47 am
I have a ton of locked files in folders I want to trash.
Is there a shortcut key (or some other way) to trashing them without having to track down the locked files and manually unlock them all?
GranitW
Re: Trashing Locked Files
on Mar 21, 2007 at 6:40:38 am
I don't think so. I personally run into this a lot and have to unlock every file. You could try logging in as root to see if this might work, but it might make the process even more complicated. The best way that I know how to do this is select all files the each folder and hold down option-command-I to open all files in the info window then deselect the check box for locking the files.
Video Specialist
Apple Developer
Owner of GranitWorks
Chuck Reti
on Mar 21, 2007 at 6:07:54 pm
http://www.apple.com/support is your friend.
See the section "Deleting locked files" in this document.
