Powerbook hard drives
COW Forums : Apple OS X
John Farrell
on Mar 1, 2007 at 3:09:05 pm
Is there an easy way to salvage data from a powerbook hard drive? I have a Lombard Powerbook G3. Finally bit the dust, and I need to get data off the disk. Short of bringing it into an Apple store and paying them to do it for me, is there an easier way? Are there external shells you can plug an internal powerbook hard drive into, for example?
John Farrell
"Digital Movies With QuickTime Pro"
http://www.charlesriver.com/titles/digitalmoviesQT.html
zrb123
Re: Powerbook hard drives
on Mar 2, 2007 at 3:24:58 am
It depends of if the Hard Drive it self has a problem. Take it to some one who knows what they are doing.
Mark Sloan
on Mar 3, 2007 at 6:39:23 am
depends on what "bit the dust" means. if there are bad sectors, booting it up in a firewire case might work, but if it is a hardware failure you would have to pay big bucks to get files retrieved.
John Farrell
on Mar 5, 2007 at 9:40:33 pm
I should have been clearer. It's not the hard drive. It was fun up until the computer stopped booting up.
John Farrell
zrb123
on Mar 5, 2007 at 10:21:51 pm
if its not booting up, it still could be the hard drive, you didn't say why its not booting up
John Farrell
on Mar 5, 2007 at 10:55:36 pm
I meant to say "fine".
Spilled some water on the table next to it. Some got on the keyboard. I pulled it away from the table, and dried the keys. Seemed okay, and then on restart...it konked out.
David Smith
on Mar 6, 2007 at 2:58:29 pm
To answer your question, yes, there are lots of cases you can buy empty, with various interfaces (Firewire 400, 800, USB.....) for 2 1/2" drives. You can pick up a USB or fw400 case for under $50. There are also adaptors out there for just pluging in a drive without a case for just the purpose you want. BUT......
You might want to try and get the G3 running, it's a great old machine. Take a look at this thread, where I got lots of suggestions for firing up a non starting Pismo. It now runs just fine.
http://www.applefritter.com/node/19891#comment-45049
John Farrell
on Mar 6, 2007 at 4:53:54 pm
Thanks, David! Good to know.
